[gdal-announce] GDAL 3.1.2 is released
Even Rouault even.rouault at spatialys.com
Tue Jul 7 05:42:09 PDT 2020
This unplanned bugfix release is mostly to fix a regression of GDAL 3.1.1 that was triggered
by programs such as GMT or PostgisRaster when reading for example GeoTIFF files. Full
releases notes below.
The sources are available at:
  https://download.osgeo.org/gdal/3.1.2/gdal-3.1.2.tar.xz
  https://download.osgeo.org/gdal/3.1.2/gdal-3.1.2.tar.gz
  https://download.osgeo.org/gdal/3.1.2/gdal312.zip
  https://download.osgeo.org/gdal/3.1.2/gdal-grass-3.1.2.tar.gz
Best regards,
Even
= GDAL/OGR 3.1.2 Release Notes =
The 3.1.2 release is a bug fix release.
== Build ==
Windows:
 * nmake.opt: add hint about adding ole32.lib to PROJ_LIBRARY for PROJ 7.1 when static
linking (#2743)
 * nmake.opt: fix ECW hints (#2748)
== GDAL core ==
* DumpJPK2CodeStream(): fix reported offset of EOC marker when PSOT = 0 (#2724)
* Overview generation: fix progress percentage when using USE_RRD=YES (#2722)
== GDAL utilities ==
* gdal2tiles: fix issue in nativezoom computation with --profile=raster on a raster whose size
is below the tile size
* gdal2tiles: fix --xyz with -p raster, fix KML generation with --xyz (fixes #2463) and update
OpenLayers export to OpenLayers 6.3.1 (#2732)
* validate_gpkg.py: add expected column type for rtree with SQLite 3.31.1
== GDAL drivers ==
ISIS3 driver:
 * make sure that in-line label size is at least 65536 bytes (fixes #2741)
PAux driver:
 * avoid ingesting large binary unrelated files (found when investigating #2722)
== OGRSpatialReference ==
* Fix crashing bug with PROJ context and OSRCleanup(), as triggered by PostGIS raster and
GMT (#2744)
== OGR drivers ==
CouchDB driver:
 * ogrcouchdblayer.cpp: fix compiler warning
DXF driver:
 * ogrdxf_leader.cpp: suppress false positive warning
FileGDB and OpenFileGDB drivers:
 * qualify DateTime values with UTC timezone when <IsTimeInUTC>true</IsTimeInUTC> is
present in layer metadata (#2719)
GeoJSON driver:
 * fix opening of file starting with {"coordinates" (#2720)
 * ogrgeojsonreader.cpp: fix compiler warning
GML driver:
 * when encountering XML issue, defer emission of error message until we return a NULL
feature, so as to avoid to confuse ogr2ogr (#2730)
== SWIG Bindings ==
Python bindings:
 * gdal.Info(): fix handling of -json in options (#2749)
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-announce/attachments/20200707/ebb39cea/attachment.html>
More information about the gdal-announce mailing list
