[gdal-announce] GDAL 3.11.0 "Eganville" is released
Even Rouault even.rouault at spatialys.com
Fri May 9 09:34:01 PDT 2025
On behalf of the GDAL/OGR development team and community, I am pleased
to announce the release of GDAL/OGR 3.11.0. GDAL/OGR is a C++ geospatial
data access library for raster and vector file formats, databases and
web services. It includes bindings for several languages, and a variety
of command line tools.
http://gdal.org/
The 3.11.0 release is a new feature release with the following highlights:
* [RFC
104](https://gdal.org/en/latest/development/rfc/rfc104_gdal_cli.html):
<b>Adding a "gdal" front-end command line interface</b>.
   - See the [list of
commands](https://gdal.org/en/latest/programs/index.html#gdal-application)
   - Includes new "gdal raster calc" and "gdal raster resclassify"
utilities.
   - "gdal raster tile", C++ port of gdal2tiles, runs faster (3x to 6x
in some cases)
   - Includes "gdal vsi list/copy/delete/move/sync" (ports of Python
sample scripts)
   - Includes "gdal driver {driver_name}" for driver-specific commands.
   - Includes smart Bash autocompletion
   - Includes C, C++, Python API
* Add [GDALG](https://gdal.org/en/latest/drivers/vector/gdalg.html)
(GDAL Streamed Algorithm Format) driver: reading of on-the-fly /
streamed vector dataset replaying compatible "gdal" command lines (kind
of VRT).
Other topics
* [RFC
100](https://gdal.org/en/latest/development/rfc/rfc100_float16_support.html):
Support float16 type
* [RFC
102](https://gdal.org/en/latest/development/rfc/rfc102_embedded_resources.html):
Embedding resource files into libgdal
* [RFC
103](https://gdal.org/en/latest/development/rfc/rfc103_schema_open_option.html):
Add a OGR_SCHEMA open option to selected OGR drivers
* [RFC
105](https://gdal.org/en/latest/development/rfc/rfc105_safe_path_manipulation_functions.html):
Add and use safe path manipulation functions
* [RFC
106](https://gdal.org/en/latest/development/rfc/rfc106_update_metadata.html):
Metadata items to reflect driver update capabilities
* [RFC
107](https://gdal.org/en/latest/development/rfc/rfc107_igetextent_isetspatialfilter.html):
Add OGRLayer::IGetExtent() and OGRLayer::ISetSpatialFilter()
* Add read-only [OGR
ADBC](https://gdal.org/en/latest/drivers/vector/adbc.html) (Arrow
Database Connectivity) driver, in particular
   with support for DuckDB or Parquet datasets (if libduckdb also installed)
* Add
[LIBERTIFF](https://gdal.org/en/latest/drivers/raster/libertiff.html)
driver: native thread-safe read-only GeoTIFF reader
* Add read-only
[RCM](https://gdal.org/en/latest/drivers/raster/rcm.html) (Radarsat
Constellation Mission) raster driver
* Add read-only AIVector (Artificial intelligence powered vector) driver
* VRT Pixel Functions: Add function to evaluate arbitrary expression
(#11209)
* Substantially improved drivers:
[ZARR](https://gdal.org/en/latest/drivers/raster/zarr.html), with
support for Kerchunk JSON and Parquet reference stores
* GeoPackage: change default version to GeoPackage 1.4 on creation (#7870)
* [RFC
108](https://gdal.org/en/latest/development/rfc/rfc108_driver_removal_3_11.html):
   - Removed raster drivers: BLX, BT, CTable2, ELAS, FIT, GSAG (Golden
Software ASCII grid),  GSBG (Golden Software 6.0 binary grid), JP2Lura,
OZI OZF2/OZFX3,  Rasterlite (v1), R object data store (.rda), RDB, SDTS,
SGI, XPM, DIPex
   - Removed vector drivers: Geoconcept Export, OGDI (VPF/VMAP support),
SDTS, SVG, Tiger, UK. NTF
   - Removed write support in following drivers: Interlis 1, Interlis 2,
ADRG,  PAux, MFF, MFF2/HKV, LAN, NTv2, BYN, USGSDEM, ISIS2
* Removed OpenCL warper
* OGR "Memory" driver deprecated, and aliased to the "MEM" driver. Its
functionality is merged into the "MEM" driver that has raster, vector
   and multidimensional support.
* Various code linting, static code analyzer fixes, etc.
* Bump of shared lib major version
New optional dependencies:
* [muparser](https://github.com/beltoforion/muparser) is *strongly*
recommended to be added as a build and runtime dependency, to provide
nominal support for C++ VRT expressions.
* [exprtk](https://github.com/ArashPartow/exprtk) may be added as a
build dependency (this is a header-only library) to provide support for
advanced C++ VRT expressions. Note that it causes an increase in libgdal
size of about 8 MB. exprtk support is recommended to be an addition to
muparser support, not as a replacement.
More complete information on the new features and fixes in the 3.11.0
release can be found at:
https://github.com/OSGeo/gdal/blob/v3.11.0/NEWS.md
Please also consult the migration guide when updating from prior releases:
https://github.com/OSGeo/gdal/blob/v3.11.0/MIGRATION_GUIDE.TXT
The release can be downloaded from:
   * https://download.osgeo.org/gdal/3.11.0/gdal-3.11.0.tar.gz - source
as .tar.gz
   * https://download.osgeo.org/gdal/3.11.0/gdal-3.11.0.tar.gz.md5 - md5sum
   * https://download.osgeo.org/gdal/3.11.0/gdal-3.11.0.tar.gz.sig -
signature
   * https://download.osgeo.org/gdal/3.11.0/gdal-3.11.0.tar.xz - source
as .tar.xz
   * https://download.osgeo.org/gdal/3.11.0/gdal-3.11.0.tar.xz.md5 - md5sum
   * https://download.osgeo.org/gdal/3.11.0/gdal-3.11.0.tar.xz.sig -
signature
   * https://download.osgeo.org/gdal/3.11.0/gdal3110.zip - source as a zip
   * https://download.osgeo.org/gdal/3.11.0/gdal3110.zip.md5 - md5sum
   * https://download.osgeo.org/gdal/3.11.0/gdal3110.zip.sig - signature
   * https://download.osgeo.org/gdal/3.11.0/gdalautotest-3.11.0.tar.gz -
test suite
   * https://download.osgeo.org/gdal/3.11.0/gdal3110doc.zip -
documentation / website
Docker images are currently cooking and should be ready in one day or so.
Best regards,
Even
http://www.spatialys.com
More information about the gdal-announce mailing list
