[gdal-dev] BuildOverviews
Frank Warmerdam warmerda at h...
Tue Jul 11 10:34:26 EDT 2000
Pierre Grout wrote:
> Hi all,
> I would like to know how to use the Dataset's Method : BuildOverviews.
> I don't know what to set for :
> - panOverviewList
List of overview reduction factors. For instance {2, 4, 8} on a base image
of 1024x1024 would give a 512x512, 256x256 and 128x128 overview.
> - pfnProgress
> - pProgressData
I have added documentation this morning. See GDALDummyProgress() on the
gdal.h page:
http://www.remotesensing.org/gdal/gdal.h.html
> My aim is to use it for making small image of the main one. (~10 x
> smaller ).
You should be able to pass panOverviewList={10} to get a 10x10 reduction.
Do you want this to be a separate file, or do you just want it for
accelerated loads with RasterIO()?
> Wich format does support to build such Overviews inside.(I know TIFF
> can, but others ? )
The SAR_CEOS, CEOS, JPEG, PNG, EFF, ESRI BIL, MFF, and PCI .aux formats
currently support external overviews (build in a .ovr file).
Keep the questions coming, and I will try to update the documentation as
things come up.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerda at h...
light and sound - activate the windows | http://members.home.com/warmerda
and watch the world go round - Rush | Geospatial Programmer for Rent
