[gdal-dev] gdal_translate question
Robert Denham
r.denham at f...
Wed Oct 25 23:24:01 EDT 2000
Yes, I think it is a version problem. I am using gdal-1.1.1, and I see
that the img writing stuff is very recent. Unfortunately I am having
trouble using cvs through our network system. I tried browsing the cvs
from the web page and grabbing what I needed, but this didn't work. I
think I will have to wait until an new version is zipped up.
Thanks,
Robert
| Robert Denham |
| School of Mathematical Sciences |
| Queensland University of Technology |
| denham at f... |
On Tue, 24 Oct 2000, Frank Warmerdam wrote:
> Robert Denham wrote:
> > Hi,
> > I am interested in using the gdal library, and thought I would get
> > started by having a look at some examples, like gdal_translate. I can
> > only seem to get this to work for GTiff formats, though I know you
> > have done lots of work on other formats. Ideally I would like to be
> > able to translate from img to say AIGrid and the reverse. But when I
> > try anything other than the default, I get
> > 0.ERROR 6: GDALDriver::Create() ... no create method implemented for
> > this format.
> > I called it like this:
> > gdal_translate -of HFA -b 1 irvine2.img irvine3.img
> > Perhaps someone could explain my problem?
> Robert,
> Only some of the formats support creation of output files. The high level
> formats list, and the individual format descriptions should (in theory) address
> what is possible.
> http://www.remotesensing.org/gdal/formats_list.html
> What version of GDAL are you using? The last source release predates the
> addition of Erdas Imagine write support, even though the online documentation
> (and code in CVS) supports this.
> You should be able to translate to formats such as JPEG, MFF, PCI .aux, and
> PNG (with various limitations) using the release version of GDAL. If you
> are intersted in Erdas Imagine .img support, I would suggest building GDAL
> from CVS.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerda at h...
> light and sound - activate the windows | http://members.home.com/warmerda
> and watch the world go round - Rush | Geospatial Programmer for Rent
