[gdal-dev] (unknown)
Frank Warmerdam warmerdam at p...
Mon Aug 20 12:04:10 EDT 2001
gilles.cherix at f... wrote:
> Hi,
> I'm trying to install mapserver with GDAL support on a Sun blade 100
> Solaris 8.
> I tried to compile the release version and the latest CVS checkout but
> it doesn't seem to like the arch ...
> The output stream of my ./configure attempt will explain the problem
> better than any word...
> Any clue would be greatly appreciated.
> Gilles
> $ ./configure
> loading cache ./config.cache
> checking for gcc... gcc
> checking whether the C compiler (gcc ) works... yes
> checking whether the C compiler (gcc ) is a cross-compiler... no
> checking whether we are using GNU C... yes
> checking whether gcc accepts -g... yes
> checking for c++... c++
> checking whether the C++ compiler (c++ ) works... yes
> checking whether the C++ compiler (c++ ) is a cross-compiler... yes
> checking whether we are using GNU C++... yes
> checking whether c++ accepts -g... yes
> checking for ranlib... ranlib
> checking for dlopen in -ldl... yes
> checking for malloc_chain_check in -ldbmalloc... no
> checking for main in -lm... yes
> checking how to run the C preprocessor... gcc -E
> checking for ANSI C header files... yes
> checking for fcntl.h... yes
> checking for unistd.h... yes
> checking for dbmalloc.h... no
> checking for dlfcn.h... yes
> checking whether byte ordering is bigendian... configure: error: can not
Gilles,
For some reason the compile and link of the trivial endian test program
is failing. Could you send me the last 30 or 40 lines of config.log?
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
