[gdal-dev] OT: OGR and Quadtree and R-tree
Paul Selormey paul at t...
Tue Aug 21 09:58:41 EDT 2001
Hello Frank,
Thanks so much for yet another great support. I have being playing with
those
algorithm but do not really know how best to put them into use. Thanks for
the enlightment.
Also, I had thought OpenEV is reading from the file directly and with the
current
speed I was satisfied. Being a Python application, it was very difficult to
tell the
among of memory being consumed-it only shows the Python runtime memory.
Points are normally all right for memory, but polygon/polyline data could be
really huge.
I had a dataset of over 240 MB from a friend the other day, with one of the
files being
as much as 100 MB and placing this in memory as my source of worry.
I will more carefully read your solutions and insight and see how best to
implement them.
I wish the author of GFC is also here to give his insight into the R-tree.
Again, thanks.
Best regards,
Paul.
----- Original Message -----
To: <gdal-dev at yahoogroups.com>
Sent: Tuesday, August 21, 2001 10:22 PM
Subject: Re: [gdal-dev] OT: OGR and Quadtree and R-tree
> Paul Selormey wrote:
> > Hello All,
> > This is really off-topic, but I could not find a good place to
> > discuss the OGR and since it is "part" of the GDAL I decided to post
> > this here.
> > Not a professional GIS person, a newbie. I have read about Quadtree
> > and R-tree and how they make rendering fast.
> > 1. Which one do you use for Shape file and MID/MIF/TAB and why?
> > 2. I have seen the implementation of the quadtree in shapelib and the
> > R-tree in GFC. However, no such algorithm is used in the OGR, why?
> > 3. I have used OpenEV, which is based on the OGR/GDAL. The rendering
> > is not all that slow, so why is the need for the quadtree?
> > 4. To anyone building a OGRLayer object and concerned with the memory
> > and speed, what is the most practical/best way to use the classes
> > provided in the OGR?
> Paul,
> 1) Shapefiles do not generally have a spatial index. ESRI programs do
> sometimes generate .sbn/.sbx files which are some sort of spatial index
but
> they are not documented. The OGR driver for shapefiles does not include
> any spatial indexing ... it doesn't even use my hacky quadtree stuff in
> shapelib at this time.
> 2) OGR is generally used for one pass translation rather than high
> performance random access, so indexing has not been a priority.
Furthermore
> indexing separately in each driver would complicate the code ... perhaps
> significantly.
> 3) Note that OpenEV vector rendering loads all the shapes into memory
making
> the speed of OGR rather irrelevant. Rendering speed of large layers of
> vectors in OpenEV isn't all that fast, especially if zoomed in on a subset
> of a large layer because OpenEV always drawns all the vectors through
OpenGL.
> However; OpenEV does demonstrate the truth that spatial indexing of
vectors
> is generally only important if you want to deal with vector large vector
> datasets (larger than can be conveniently held in RAM for instance).
> 4) OGR doesn't really provide any support functions to simplify
implementing
> a high performance driver; however, it does provide important hooks that a
> driver can implement to provide better performance to the application. In
> particular, if applications set a spatial or attribute query a given
OGRLayer
> implementation can choose to implement it internally in a smart way to
provide
> good performance. Make sure you override GetExtent() and
GetFeatureCount()
> so the default implementations (which result in reading the whole dataset
> once) are not used. Also, if you want to provide high performance, make
sure
> that random reads are supported.
> Finally, try to return meaningful results from your TestCapability() call.
> While OGR formats can be implemented fairly efficiently; if you are
> super-sensitive to performance, going through OGR is likely not the most
> efficient mechanism. OGR adds a non-trivial overhead in terms of making
> and destroying the OGRFeatures. That is why something like MapServer
> which is very performance sensitive renders directly from a
hacked/optimized
> shapelib instead of going through a nice general library like OGR. Well,
it
> does have the option of going through OGR, but it's most optimized option
> is still the direct from shape method.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at p...
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
