[gdal-dev] Large Raw Files
ldjohn at u...
ldjohn at u...
Wed Dec 12 14:18:51 EST 2001
On Wed, 12 Dec 2001, Frank Warmerdam wrote:
> Lowell and Others,
> I have altered the RawRasterBand class so it includes an optional
> extra bIsVSIL parameter. If FALSE (the default), then the normal
> VSI API will be used for file IO, and files may only be up to 2GB. If
> TRUE then the large file API (ie. VSIFSeekL(), VSIFReadL() and VSIFWriteL())
> will be used instead of the regular one.
> I have altered the PAux, and HKV (aka MFF2) formats to utilize this.
> To utilize this for LDF please ensure that you use the large file API
> to open and access your file, and pass bIsVSIL=TRUE when in the constructor
> call to RawRasterDataset. Let me know if you have questions about how to
> use the large file API.
> I don't have any convenient way to test this, so if you could do some testing
> with 5GB LDF and PAux files I would appreciate it.
> The large file API changes can be extented to other formats like ESRI labelled
> BIL, Envisat, and SAR_CEOS if needed. Anyone who wants this, and is willing
> to test it let me know and I will make the changes.
Thanks! I'll try to get the LDF drivers modified and tested
shortly. Then I'll get back to you with the results.
Lowell
Lowell D. Johnson
Software Engineering
Raytheon Systems
EROS Data Center
47914 252nd Street, Mundt Federal Bldg
Sioux Falls, SD 57198
