[gdal-dev] libproj.so on Linux?
Daniel Morissette
danmo at v...
Thu Dec 27 22:16:43 EST 2001
Ben Discoe wrote:
> Sure enough, i ran "/sbin/ldconfig" again as root, and it seems to have
> fixed the problem! <scratches head> It's puzzling, since i had already
> added /usr/local/lib long ago, and other libraries in that folder were
> already working and being found... i guess "ldconfig" does more than just
> check the paths in ld.so.conf.
Running ldconfig refreshes the libpath cache... it needs to be run after
new libs are installed and before they can be used.
Daniel Morissette morissette at d...
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
