libgrass5 1.0.0 release
Frank Warmerdam warmerdam at p...
Fri Nov 2 15:10:43 EST 2001
Folks,
I have prepared a 1.0.0 release of libgrass. The most noteworthy change
in this release is support for the new (LZW-free) compression format for
GRASS rasters incorporated into GRASS roughly 8 months ago. Note that old
compressed rasters will nolonger be readable.
The library is also updated to mostly current code from libgis.
General info:
http://gdal.velocet.ca/projects/grass
Direct download:
http://gdal.velocet.ca/projects/grass/libgrass5-1.0.0.tar.gz
Amoung other things, libgrass is used by OSSIM and GDAL to get access to
GRASS databases.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
