[gdal-dev] Compiling on cygwin
Tyler Mitchell tmitchell at l...
Tue Nov 6 17:54:01 EST 2001
I reran the make and still get the same errors when I turn of ecw. But I
think I may be wasting my time. You tell me.
I basically want to get ecw support for mapserver. I had thought I would
need to use cygwin (that is, build gdal and mapserver on cygwin) to do
this. But I've got the mapserv.exe directly for windows and just need to
get a windows build of gdal (with ecw support). Right? I am sure that my
blurred understanding of what requires gdal and what gdal requires is
becoming evident. I have openev installed and noticed gdal exes in there -
it is a version with ecw support - do I already have what I need?
Tyler J. Mitchell
Coordinator - Geographic Information Systems
Lignum Ltd - 180 Hodgson Road
Williams Lake, B.C. Canada
V2G 3P6
Phone: 250-392-3371
Fax: 250-398-3977
Email: tmitchell at l...
Frank
Warmerdam To: gdal-dev at yahoogroups.com
<warmerdam at pob cc:
ox.com> Fax to:
Subject: Re: [gdal-dev] Compiling on cygwin
11/06/01 02:30
PM
Please respond
to gdal-dev
Tyler Mitchell wrote:
> Hi guys,
> Is there anything special I need to do to get gdal compiled on cygwin?
> Here's the error I'm getting:
> ./configure --with-tiff=internal --with-geotiff=internal
> --with-jpeg=internal
> #I have also enabled ECW support
> make clean
> make
> /usr/lib/libm.a(_cygwin_crt0_common.o): In function `cygwin_crt0_common':
/cygnus/netrel/src/cygwin-1.3.3-2/winsup/cygwin/lib/_cygwin_crt0_common.cc:90:
> u
> ndefined reference to `GetModuleHandleA at 4'
> make: *** [force-lib] Error 1
> Administrators at PCWLF20 /usr/src/gis/gdal-1.1.5
Tyler,
I have never run into this problem, and I am not sure where
GetModuleHandleA
is being called from. Note that I have never tried using ECW from within
Cygwin. I didn't realize you were supposed to be able to call out to
external
DLLs without doing something special. Perhaps you could try it again
without
ECW and see if that is your problem?
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
