[gdal-dev] Compiling on cygwin
Tyler Mitchell tmitchell at l...
Tue Nov 6 18:41:31 EST 2001
>If you have the 1.2.1_FW OpenEV release, then you should have everything
you
I've got it.
>need (assuming your MapServer is built with GDAL support).
I downloaded a nightly build of MS that says it supports gdal...
>Just copy the
>gdal11.dll, NCS*.dll and perhaps the OGDI, ZLIB and EXPAT DLLs rom the
>OpenEV release into whereever you have your gdal11.dll currently for
>and you should be all set.
...but all I got from the MS zip is a few exe and a zlib dll. No gdal dll
at all elsewhere on my system. I'll look into it at the mapserver download
site.
>In the meantime, verify that your OpenEV can open ECW files.
Sure does.
