GDAL/OGR 1.1.5 Released
Frank Warmerdam
warmerdam at p...
Sat Sep 15 11:07:37 EDT 2001
Folks,
I have finally prepared and released what I consider to be GDAL 1.1.5. I am
attaching a lengthy list of features and bug fixes since the 1.1.4 release
early in the year.
With this release I am also considering the GDAL source releases to be the
place to get OGR, and so I am including notes on OGR changes in the overall
change document. By default OGR is now built into GDAL shared libraries
(unless --without-ogr is selected at configure time).
The source can be fetched from:
ftp://ftp.remotesensing.org/gdal/gdal-1.1.5.tar.gz
ftp://ftp.remotesensing.org/gdal/gdal115.zip
It is my intention that this be the base release used by GRASS 5.0,
and MapServer 3.5. I will likely announce this release (with more background
info on GDAL) on some of the other related lists and news groups next week if
people don't immediately start reporting problems.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
GDAL 1.1.5 New Features:
o AIGrid:
- Return nodata value.
o OGDI:
- Added format user documentation.
- Added Sub Dataset support.
- Utilize OGDI 3.1 style capabilities metadata.
o SAR_CEOS:
- Added support for Alaska SAR Toolbox naming convention.
- Read map projection record for corner GCPs.
o PNG Driver:
- read/write support for transparency via colortable and nodata value.
o Erdas Imagine (HFA) Driver:
- Added support for reading external large image files.
- Added support for uncompressed, but reduced precision blocks.
o GIF Driver:
- Added .wld world file support.
- Added transparency read support.
- Upgraded to libungif 4.x.
o JPEG Driver:
o PAux Driver:
- Added limited gcp and projection read support.
o GeoTIFF Driver:
- Added specialized support for 1 bit files.
- Upgraded world file reading (added .wld files), use
GDALReadWorldFile().
o JDEM Driver is new (Japanese DEM format).
o FujiBAS Driver is new.
o ERMapper ECW Driver is new.
o GDAL Bridge: upgraded to include new entry points, like GCP access and
nodata api.
o gdal_translate: added the -not_scrict option.
o GDALGetRandomRasterSample(): Return magnitude for random samples.
o Added use of CPL_CVSID macro in most source files. Running the RCS ident
command on any GDAL executable or shared library should now give a listing
of most object file versions from which it was built.
o Various improvements so that static builds will work under Cygwin.
o Various improvements so that builds can be done on MacOS X.
o Overviews: Implement AVERAGE_MAGPHASE option for complex image overviews.
o Added support for sub datasets to gdalinfo, core api and OGDI raster driver.
o The size of the GDAL cache can now be overridden with the GDAL_CACHEMAX
environment variable (measured in MB).
o Added Driver implementation tutorial to documentation.
o Added apps/gdaltindex.c - application for building tile indexed raster
datasets suitable for use with UMN MapServer.
GDAL 1.1.5 Significant Bug Fixes:
o SAR_CEOS:
- Don't try to get GCPs from scanlines with no prefix data.
o GeoTIFF:
- Fixed handling of RGBA band ordering on big endian systems.
- Fixed bugs in overview generation, especially when updating in place.
o gdal-config should work properly in all situations now.
o JPEG Driver: improved magic number tested to avoid ignoring some jpeg files.
o FITS Driver: lots of fixes and improvements.
OGR 1.1.5 New Features:
o Implemented support for attribute query filters (SetAttributeFilter())
on OGRLayer, provided SWQ based implementation, plugged into all
drivers and added hooks to ogrinfo.
o MapInfo Driver:
- Added accelerated spatial query support.
- Upgraded to current MITAB source as of GDAL release date.
o S-57 Driver:
- Added support for applying S-57 updates automatically.
o SDTS Driver:
- Added ENID and SNID to line features.
- Return coordinate system in WKT instead of PROJ.4 format.
o Shapefile Driver:
- Auto determine shapefile type from first object written.
- Added good support for NULL shapes, and NULL attribute fields.
- Added support for .prj files (read and write).
o PostgreSQL Driver:
- Added PostGIS support.
- Pass attribute queries through to PostgreSQL.
o NTF Driver:
- Added support for GTYPE 5 geometries (a type of arc).
- Added support for GEOMETRY3D records in indexed (generic) datasets.
o TIGER/Line Driver:
- Added write support.
- Improved read support for TIGER 2000.
o OLE DB Provider:
- Added support for spatial queries via ICommand parameters.
- Added support for attribute queries by parsing out WHERE clause.
- In general substantial rework and extentions were made to make it
work with ESRI and AutoDesk clients.
o Added gdal/data/stateplane.txt - a test file with one line per state plane
zone for applications wanting to present options to users.
o Install ogrsf_frmts.a on install if building with OGR support enabled.
o Reports layer extents in ogrinfo.
OGR 1.1.5 Significant Bugs:
o OGRSpatialReference:
- Fix bug with extracting linear units from EPSG derived definitions.
- Fixed bug translating LCC from EPSG to WKT (importFromEPSG()).
- Improved IsSame() test for GEOGCS now.
- Fixed crash if PROJECTION missing from PROJCS definition.
o S-57:
- Improve recovery from corrupt line geometries.
- Read objects as generic if the object class is not recognised.
- Handle LIST attributes as a string, instead of as a single int.
o NTF:
- Fixed circle conversion to polylines to close the circle properly.
- Upped MAX_LINK to 5000 to handle much more complex geometries.
o DGN:
- Don't include elements with the complex bit set in extents
computations.
o OGRGeometry:
- Fixed WKT format (import and export) for various container types.
- WKT import fixed for coordinates, and Z coordinates.
