[gdal-dev] Re: Calibration in GDAL
Andrey Kiselev dron at a...
Thu Aug 1 11:01:42 EDT 2002
Frank,
Now I'm suggest the next scheme for implementing calibration.
class GDALCalibrationModel
public:
GDALCalibrationModel( char **papszModelDescription );
GDALCalibrationModel( );
CreateFromDescription( char **papszModelDescription );
~GDALCalibrationModel( );
double GetCalibratedValue( int iXPos, int iYPos, double dfValue );
CPLErr DumpToFile( const char * pszFilename );
CPLErr ReadFromFile( const char * pszFilename ); /* ??? */
Class instances will be initialized by the string list like this:
"METHOD=<method for applying calibration>" [PIXEL|ROW|COLUMN]
"FUNCTION=<type of calibration function>" [POLY|PICEWISE_POLY|LUT]
"COEFFS0=<list of the zero-order coefficients>" [number of coefficients
depends from value of the METHOD field]
"COEFFS1=<list of the first-order coefficients>"
Only "METHOD" and "FUNCTION" keys are obligatory, number and meaning of
other parameters depends from "FUNCTION" field. During the initialization
the new metadata domain (GDAL_CALIBRATION) will be created and filled by the
corresponding values.
Does this conforms with your vision of problem?
Andrey V. Kiselev
Scientific Research Center for Ecological Safety Russian Academy of Sciences
Office phone: +7 812 2307834 ICQ UIN 26871517
Registered Linux user number 169907
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20020801/0299fb40/attachment.bin
