[gdal-dev] Re: any reason for a linked statically gdalinfo?
Buchan Milne bgmilne at c...
Tue Aug 20 05:44:01 EDT 2002
gdal_dev_reader wrote:
> Frank,
>>There is no compelling reason for gdalinfo to be linked statically. I
>>do that just so that I can verify that static linking still worked as expected.
> from a packaging perspective 1Mb less is an appelling feature :)
> it wuold be nice if you could move the static-link test to a
> non-installed binary. gdal2raw and gdalindex look like candidates
> (actually, i'd like to see the dinamically linked gdal2raw in the
> default install, any chache?), test1 would be the perfect one,
> but it looks like a stale rule...
How about an alternative rule (make check-static) instead.
I have put a gdal package into Mandrake, using the default make rule,
halving it's size is appealing ...
Btw, any time frame for SONAME support?
Buchan
|----------------Registered Linux User #182071-----------------|
Buchan Milne Mechanical Engineer, Network Manager
Cellphone * Work +27 82 472 2231 * +27 21 8828820x121
Stellenbosch Automotive Engineering http://www.cae.co.za
GPG Key http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
