[gdal-dev] Use of the virtual dataset/rasterband
Paul Selormey paul at t...
Wed Aug 28 09:04:30 EDT 2002
Hello Frank,
Thanks for the response.
> Yes, somebody somewhere is at home. In fact, even I am.
Thank God!
> The virtual dataset "format" is a way of writing an XML description of a
> dataset where the image data is derived from other GDAL supported
datasets.
> It has a number of potential uses including:
> o A way of creating a dataset with different, or complete metadata
without
> copying image data.
> o A mechanism to merge bands from many files into one.
> o A way to create a subsetted dataset (without copying image).
> o A way to build a virtual mosaic from a set of data files.
Sounds good, I will also see how best to exploit it.
Again, thanks for the information.
Best regards,
Paul.
