[Gdal-dev] reading linear units from GeoTIFF broken?
Frank Warmerdam
warmerdam at pobox.com
Tue Dec 3 09:19:44 EST 2002
Vladimir Slepnev wrote:
> write it into a newly created GeoTIFF file through GDAL (SetProjection()),
> here's a piece of listgeo info for the newly written file:
> Keyed_Information:
> GTModelTypeGeoKey (Short,1): ModelTypeProjected
> GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
> GTCitationGeoKey (Ascii,33): "UTM Zone 13, Northern Hemisphere"
> GeographicTypeGeoKey (Short,1): GCS_WGS_84
> ProjectedCSTypeGeoKey (Short,1): User-Defined
> ProjectionGeoKey (Short,1): Proj_UTM_zone_13N
> ProjLinearUnitsGeoKey (Short,1): Linear_Foot
> End_Of_Keys.
> End_Of_Geotiff.
Vladimir,
I get the same results in the GeoTIFF file.
> read the same file through GDAL, get the WKT projection string
> (GetProjectionRef()):
> PROJCS["unnamed",GEOGCS["WGS
> 84",DATUM["WGS_1984",SPHEROID[,6378137,298.2572235630016,AUTHORITY["EPSG",70
> 30]],AUTHORITY["EPSG",6326]],PRIMEM["Greenwich",0],UNIT["degree",0.017453292
> 5199433],AUTHORITY["EPSG",4326]],PROJECTION["Transverse_Mercator"],PARAMETER
> ["latitude_of_origin",0],PARAMETER["central_meridian",-105],PARAMETER["scale
> _factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing
> ",0],UNIT["unknown",1]]
For me the unit is read back properly. I suspect the new EPSG 6.2.2 .csv
files are not being found correctly. Have you done a 'make install'? If
not, what is your GEOTIFF_CSV set to? You can likely work around this
by defining the GEOTIFF_CSV environment variable and pointing it to your
gdal/data directory, but the default situation is that the .csv files
should be installed in /usr/local/share/gdal and that the default search
rules in GDAL should find them there.
It would appear that isn't happening in your case.
> Once again, sorry for the inconvenience...
> our correspondence seems to be a major part of gdal-dev by now :-)
> And thanks a lot for your help with all this stuff.
No sweat. You are helping me fix bugs, and improve the driver with very
cogent bug reports.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
