[Gdal-dev] Re: vrt loading as strings
gwalter at atlsci.com
Thu Dec 5 17:42:55 EST 2002
Hi Frank,
I've just tried loading a vrt by passing gdal.Open() a string with the vrt
contents, but it didn't work. I get the error below. Do I need to do something
special in formatting the string? I just read in all the lines and concatenated
them by adding them to each other.
ERROR 4: `<VRTDataset rasterXSize="256" rasterYSize="256">
<VRTRasterBand dataType="Byte" band="1">
<ColorInterp>Red</ColorInterp>
<SimpleSource>
<SourceFilename>mandrill.tif</SourceFilename>
<SourceBand>1</SourceBand>
<SrcRect xOff="0" yOff="0" xSize="512" ySize="512"/>
<DstRect xOff="0" yOff="0" xSize="256" ySize="256"/>
</SimpleSource>
</VRTRasterBand>
<VRTRasterBand dataType="Byte" band="2">
<ColorInterp>Green</ColorInterp>
<SimpleSource>
<SourceBand>2</SourceBand>
</SimpleSource>
</VRTRasterBand>
<VRTRasterBand dataType="Byte" band="3">
<ColorInterp>Blue</ColorInterp>
<SimpleSource>
<SourceBand>3</SourceBand>
</SimpleSource>
</VRTRasterBand>
</VRTDataset>
' does not exist in the file system,
and is not recognised as a supported dataset name.
Gillian
Frank Warmerdam wrote:
> I would add that it is possible to pass the entire contents of the VRT
> file as a string to gdal.Open() and it will get opened "as if" it were
> reading the file from disk.
> The fixes for out-of-place labels should be done within the next three
> weeks as well as investigating the upsidedown raster problem. It may
> well be that for your next release you should disable the display list
> support by default if we don't completely trust it yet.
> You might also want to look into the upside rasters yourself if you
> have time. The raster symbol rendering support is in the
> gv_shapes_draw_symbol() function in gvshapeslayer.c.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
