[Gdal-dev] Landsat 7 TM
javier garcia andresjavier.garcia at wanadoo.es
Tue Dec 10 11:46:48 EST 2002
Hi;
I've compiled GRAS5.0 against gdal-1.1.7.1 (downloaded from binaries for
Linux); but I can't import FAST-L7A format (Landsat TM data). I obtain a
message that says that the format is not supported.
It seems to be a problem of gdal. Isn't it?
If so. Can we expect to import this shortly?
Thank you very much.
A. Javier García
Water and Soil Conservation Department
CEBAS-CSIC
Apartado 4195
30080 Murcia
Spain
Tel.: +34 968 39 63 90
Fax: +34 968 39 62 13
