[Gdal-dev] Landsat 7 TM
Tue Dec 10 13:28:25 EST 2002
javier garcia wrote:
> Hi, Andrey.
> gdalinfo --formats doesn't work for me. What I can do is:
>>gdalinfo --version
> GDAL 1.1.7, released 2002/04/16
> Do you think is it too old to support FAST: EOSAT FAST Format?
> Could you tell me if the output of your "gdalinfo --version" is different
> than mine?
Javier,
The FAST support was implemented in September.  You will need to upgrade,
presumably to the daily snapshots as Andrey had suggested.
Best regards,
