Makefile bug
ldjohn at u... ldjohn at u...
Thu Jan 31 11:56:03 EST 2002
Hello Frank,
One of our team members had a problem with a fresh build of GDAL. Here is
the error:
ld32: WARNING 84 : ../ogrsf_frmts.a is not used for resolving any symbol.
ld32: FATAL 9 : I/O error (../../ogr.a): No such file or directory
make[3]: *** [gmlview] Error 2
make[3]: Leaving directory
`/sg1/csb/tbeckman/las/newio/gdal/ogr/ogrsf_frmts/gml'
make[2]: *** [default] Error 2
make[2]: Leaving directory
`/sg1/csb/tbeckman/las/newio/gdal/ogr/ogrsf_frmts'
make[1]: *** [sublibs] Error 2
make[1]: Leaving directory `/sg1/csb/tbeckman/las/newio/gdal/ogr'
make: *** [ogr-target] Error 2
Looking at the gdal/ogr/GNUmakefile, it appears that the ogrsf_frmts
directory is built before ogr.a, but stuff in the newly-added gml
directory wants to link with ../../ogr.a.
So here is the proposed patch:
66c66
< $(FRMTS_LIB):
> $(FRMTS_LIB): $(OGR_LIB)
It seems to work for us.
By the way, my work on the GDAL interface is coming to a close, so that
work will be passed to a teammate from whom you will probably be hearing
in the near future.
Thanks for all of you help!
Lowell
Lowell D. Johnson ldjohn at u...
Software Engineering
Raytheon Systems
EROS Data Center
47914 252nd Street, Mundt Federal Bldg
Sioux Falls, SD 57198
