[gdal-dev] Re: Calibration in GDAL
Paul Selormey paul at t...
Wed Jul 31 20:55:59 EDT 2002
Hello Frank and Andrey,
I need a little education here. What is the use of the so-called
calibrated raster? (I have always associated calibration to instruments).
Best regards,
Paul.
----- Original Message -----
To: "Andrey Kiselev" <dron at a...>
Cc: "gdal-dev" <gdal-dev at yahoogroups.com>
Sent: Thursday, August 01, 2002 12:23 AM
Subject: [gdal-dev] Re: Calibration in GDAL
> Andrey Kiselev wrote:
> > Hi, Frank,
> > I'm thinking about adding calibration feature to the GDAL and I need
your
> > opinion. I'm suggest follows:
> > 1. Add a helper class for storing polinomial coefficients on per pixel
> > basis. It may be something like
> > class Calibration
> > int iOrder;
> > double *padfCoefficients;
> > public:
> > Calibration( int, double * );
> > ~Calibartion( );
> > double CalibrateValue( double );
> > /* padfInputArray --- Array of polinomial coefficients */
> > Calibration::Calibration( int iOrder, double *padfInputArray )
> > if ( iOrder == 0 )
> > return NULL;
> > iOrder = ABS( iOrder );
> > padfCoefficients = CPLMalloc( iOrder * sizeof(double) );
> > for ( int i = 0; i< iOrder; i++ )
> > padfCoefficients[i] = padfInputArray[i];
> > double Calibration::CalibrateValue( double dfValue )
> > double dfCalibratedValue = 0;
> > for ( int i = iOrder; i > 0; i-- )
> > dfCalibratedValue =
> > (dfCalibratedValue + padfCoefficients[i]) * dfValue;
> > return dfCalibratedValue;
> > 2. Each driver which supports calibartion should define method
> > virtual double GDALRasterBand::GetCalibratedValue( int iXPos, int iYPos,
> > double dfValue );
> > in the GDALRasterBand class. This method will return calibrated value
for
> > the specified pixel (value of pixel passed through dfValue parameter).
In
> > the Open() method for the dataset calibration array will be created and
> > filled. In case of the same function for all pixels it will be something
> > like (schematically)
> > Calibration *paCal = new Calibration[nBands];
> > If we have different functions for different rows it will be
> > Calibration **papCal = new Calibration[nBands][nYSize];
> > And if we have the same function for all rows
> > Calibration **papCal = new Calibration[nBands][nXSize];
> > 3. GDALRasterBand::RasterIO() method should take a flag indicating that
we
> > want to get calibrated values. Maybe something like GF_ReadCalibrated as
the
> > first parameter? Actually they will be calculated using
> > GetCalibratedValue().
> > What do you think about all of these?
> Andrey,
> I have included all of your original text above so others on the gdal list
> can follow the discussion.
> I think that:
> o The calibration information has to be transportable from one driver to
> another, so we should not entirely hide it within the driver.
> o We should support a calibration scheme that can potentially support
multiple
> calibration model types without having to alter the public API.
> Inorder to accomplish this I suggest that we implement a
GDALCalibrationModel
> class that initially:
> o Can be initialized from a string list representation of a calibration
model.
> o Has a method to calibrate a single value given the value as a double
and
> the location as an integer pixel,line location from within the source
image.
> o Supports whatever polynomial scheme you initially need.
> o Implement a convenience mechanism for storing calibration models in an
> external text file. This mechanism could be easily plugged into
formats
> that don't currently support calibration in much the way we support
world files
> or external overview files for many formats now. Ensure this
convenience
> mechanism is utilized for GeoTIFF format.
> and that would eventually offer methods for;
> o Converting back to a string list model format.
> o Altering the calibration model (if needed) to account for subsetting
of an image.
> o Support additional calibration models as we need them.
> o Include a method on the GDALRasterBand() for reading calibrated data
that
> would internally take care of instantiating the GDALCalibrationModel
> perhaps called CalibratedRasterIO() (read-only though).
> I think that calibration models should be fetched, and set on the
GDALRasterBand
> via the metadata mechanism, using a special domain (perhaps
"BMD_CALIBRATION_MODEL").
> Within this special domain there would be standard keys for the
calibration model
> type, and perhaps a description field. The rest of the key/value pairs
would be
> model type specific. The whole stringlist of metadata from this domain is
the
> serialized format of the calibration model.
> The one concern about my suggested approach is that for formats for which
the
> calibration model for the whole file would be very big it will be
necessary to
> convert it to the string list format, and back into a GDALCalibrationModel
all
> in memory. If we forsee this being a big problem we should rethink things
a
> bit.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at p...
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
