[gdal-dev] installing CVS version
Norman Vine
nhv at y...
Wed Mar 27 20:07:53 EST 2002
charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
Tyler Mitchell writes:
>I just successfully ran "make" on Cygwin with gdal from CVS.
>But now when
>I run "make install" I get this error. Any suggestions to
>work around/fix this?
>(cd pymod; make install)
>make[1]: Entering directory `/usr/src/gis/gdal/pymod'
>../install-sh -d /usr/lib/python2.2/site-packages
>for f in *.py _gdalmodule.so ; do ../install-sh -c $f
>/usr/lib/python2.2/site-packages ; done
>install: _gdalmodule.so does not exist
>make[1]: *** [install] Error 1
>make[1]: Leaving directory `/usr/src/gis/gdal/pymod'
>make: *** [install-actions] Error 2
attached find my modified for Cygwin makefile for $GDAL / pymod
I also use a slightly modfied GDALmake.opt but I think that this
should work with the standard one. If not holler :-)
Cheers
Norman
Name: not available
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20020327/853ad83c/attachment.obj
