[gdal-dev] installing CVS version
Tyler Mitchell
tmitchell at l...
Thu Mar 28 11:41:27 EST 2002
Hey, thanks for the help Norman.
It doesn't complain about that anymore - it complains about something else
make[1]: Entering directory `/usr/src/gis/gdal/pymod'
../install-sh -d /usr/lib/python2.2/site-packages
for f in *.py _gdalmodule.dll ; do ../install-sh -c $f
ackages ; done
install: _gdalmodule.dll does not exist
make[1]: *** [install] Error 1
make[1]: Leaving directory `/usr/src/gis/gdal/pymod'
make: *** [install-actions] Error 2
"Norman Vine"
<nhv at y... To: <gdal-dev at yahoogroups.com>
> cc:
Fax to:
03/27/2002 Subject: RE: [gdal-dev] installing CVS version
05:07 PM
Please respond
to gdal-dev
ADVERTISEMENT
(Embedded image moved to file:
pic19762.gif)
(Embedded image My Groups | gdal-dev Main Page
moved to file:
pic14686.gif)
pic15809.gif)
Tyler Mitchell writes:
>I just successfully ran "make" on Cygwin with gdal from CVS.
>But now when
>I run "make install" I get this error. Any suggestions to
>work around/fix this?
>(cd pymod; make install)
>for f in *.py _gdalmodule.so ; do ../install-sh -c $f
>/usr/lib/python2.2/site-packages ; done
>install: _gdalmodule.so does not exist
attached find my modified for Cygwin makefile for $GDAL / pymod
I also use a slightly modfied GDALmake.opt but I think that this
should work with the standard one. If not holler :-)
Cheers
Norman
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. (See
attached file: GNUmakefile)
Name: not available
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20020328/b013aca5/attachment.gif
Name: not available
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20020328/b013aca5/attachment-0001.gif
Name: not available
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20020328/b013aca5/attachment-0002.gif
Name: not available
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20020328/b013aca5/attachment.obj
