[gdal-dev] Re: Linux Binary Release
Buchan Milne bgmilne at c...
Mon May 27 10:41:50 EDT 2002
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Frank Warmerdam wrote:
| gdal_dev_reader wrote:
|>hi,
|>any reason for libgdal.1.1.so to be named that way (as opposed to
|>libgdal.so.1.1 that seems more standard, at least on linux?) and to
|>have no SONAME?
|>regards,
|>alessandro
| Alessandro,
| There is no compellingly good reason, but basically I name it differently
| to make it clear I am not using the normal shared library mechanisms for
| version control.
So how should people:
1)Get gdal into a linux distro (where packaging standards require the
ability to have multiple versions of the same library, but of different
SONAME).
2)Ensure that they are using the same API as the binary shared library?
I would like to see standard shared library support. Is there are good
reason NOT to use it (of course, the library version does not have to
correspond to the software version anyway, look at gconf ;-)).
This is why I would like to see it:
http://ranger.dnsalias.com/mandrake/mandrake8.2/grass/
Regards,
Buchan
|----------------Registered Linux User #182071-----------------|
Buchan Milne Mechanical Engineer, Network Manager
Cellphone * Work +27 82 472 2231 * +27 21 8828820x202
Stellenbosch Automotive Engineering http://www.cae.co.za
GPG Key http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE88kWtrJK6UGDSBKcRAhBbAKCjkATEFv6ZCBo/e7J19S8+FJLVgQCgpbip
cTasJ1f9WEaT+yqLvG0VZ0I=
=FvdQ
-----END PGP SIGNATURE-----
