On Proj4...
Paul Selormey
paul at t...
Wed May 29 07:44:43 EDT 2002
Hello All,
As I have stated earlier, I am working to remove all the macros style codes
to
a more readable version of the projection library.
With the exception of the PROJ_HEAD in the pj_list.h file, I have completed
the
removal from all other files. I am not removing the constants.
I have found two problems and need some help...
1. One file strtod.c is a GPL code. Is the Proj4 therefore not under GPL?
and other
libraries using it?
2. One file biveval.c still contains one pre-ANSI C function.
/* basic bivariate Chebyshev evaluation */
static double ceval(C, n) struct PW_COEF *C;
what is the right ANSI version of this function. I could not get this right
(it seems
the "n" is an integer!) :(
I will post the final codes for all to evaluate and then start work on
porting to C++.
I know many will still prefer this
ENTRY0(leac)
P->phi2 = pj_param(P->params, "rlat_1").f;
P->phi1 = pj_param(P->params, "bsouth").i ? - HALFPI: HALFPI;
ENDENTRY(setup(P))
to this:
const char * const pj_s_leac = des_leac;
PJ *pj_leac(PJ *P)
if (!P)
if( (P = pj_malloc(sizeof(PJ))) != ((void *)0))
P->pfree = freeup;
P->fwd = 0;
P->inv = 0;
P->spc = 0;
P->descr = des_leac;
return P;
else
return (setup(P));
However, the macro-free version will make it earsier to port the library to
C++/Java/C# etc
and that is my goal.
Best regards,
Paul.
