[gdal-dev] GDAL/OGR symbol missing from .so
s duclos
sylvain_duclos at y...
Fri Oct 4 10:46:13 EDT 2002
Hi Frank,
I think I found my problem
I updated gdal, compiled it, but didn't install
(10SEP02). Same for openev.
Later I updated/install openev &
install gdal (now out of sync)
So I went right into gdal to fix it.
My modification appened to be the same as the one
in cvs so diff was silent (from what I can see
from cvs annotate.)
The morale of the story:
1-update downstream stuff first
2-compile/install/RUN
3-then try to fix
I went the other way around :(
Sorry for the 'noise'!
rgds,
Sylvain.
> s duclos wrote:
> > Hi,
> > On Linux symbol in ogr_api.o are not lib.so.
> > Simple patch bellow ...
> > brgds,
> Sylvain,
> ogr_api.o is already in GDALmake.opt.in. Perhaps
> you hadn't rerun
> configure?
> Best regards,
__________________________________________________
Do you Yahoo!?
New DSL Internet Access from SBC & Yahoo!
http://sbc.yahoo.com
