[gdal-dev] Re: netcdf in gdal
Norman Vine nhv at c...
Tue Oct 8 14:15:43 EDT 2002
Frank Warmerdam writes:
> Peter Cromwell wrote:
> > Dear Frank,
> > I am investigating the possibility of adding NetCDF to the
> > raster formats supported by GDAL.
> > Are there any reasons why it would not be a good idea.
> > To avoid duplicating effort, do you know whether someone has
> > done this already or is working on it?
> Peter,
> I think the folks who work on DODS have already written NetCDF support for
> GDAL. James, could you comment on that? What happened with regard to
> migrating your GDAL DODS driver back into the GDAL core?
> Also, others (ie. Norman Vine) have expressed an interest in having NetCDF
> support in GDAL.
Hi All
It would be nice to have native GDAL support for NetCDF
but it is relatively easy to use a Python bridge
Here is a Python snippet that will transform an arbritrary GDAL grid
into a NetCDF grid
Enjoy
Norman
==== cut ====
#!/usr/bin/env python
GDAL_2_GMT -- Convert a GDAL file to a GMT grid file
built on top of Konrad Hinsen's NetCDF module
http://starship.python.net/crew/hinsen/scientific.html
Frank Warmerdam's GDAL extension module.
http://www.remotesensing.org/gdal/index.html
inspired the by wgrd function in Janko Hauser's NCfns module
http://starship.python.net/crew/jhauser/NCfns.py.html
Can optionally use NCAR's excellent regridding routines
http://esg.llnl.gov/cdat/
__version__ = '0.2.1'
__email__ = 'nhv at c...'
__author__ = 'Norman Vine'
import os,sys,string
from Scientific.IO.NetCDF import *
import Numeric
import gdal
import math
# import adamsregrid
def wgrd(z,x,y,fname,title="no_title",name="dummy",
scale=1.,offset=0,
xunit="dummy",yunit="dummy",zunit="dummy"):
"""wgrd(z,x,y,fname,title=None,name=None,
scale=None,factor=None,
xunit=None,yunit=None,zunit=None)
Writes a grd-file suitable for GMT
#print "NetCDFFile"
fn=NetCDFFile(fname,'w')
#print "Creating Fields"
# create all of our fields
fn.createDimension('side',2)
fn.createDimension('xysize',Numeric.product(z.shape))
fn.createVariable('x_range',Numeric.Float64,('side',))
fn.variables['x_range'].units=xunit
fn.createVariable('y_range',Numeric.Float64,('side',))
fn.variables['y_range'].units=yunit
fn.createVariable('z_range',Numeric.Float64,('side',))
fn.variables['z_range'].units=zunit
fn.createVariable('spacing',Numeric.Float64,('side',))
fn.createVariable('dimension',Numeric.Int32,('side',))
fn.createVariable('z',Numeric.Float32,('xysize',))
fn.variables['z'].long_name=name
fn.variables['z'].scale_factor=scale
fn.variables['z'].add_offset=offset
fn.variables['z'].node_offset=0
fn.title=title
fn.source="created by NumPy"
# Fill the fields
fn.variables['x_range'][0]=x[0]
fn.variables['x_range'][1]=x[1]
fn.variables['spacing'][0]=x[2]
fn.variables['y_range'][0]=y[0]
fn.variables['y_range'][1]=y[1]
fn.variables['spacing'][1]=y[2]
# determine zmin,zmax
print "checking min,max"
zmin = 100000.0
zmax = -100000.0
for zrow in z:
zmin = min(min(zrow),zmin)
zmax = max(max(zrow),zmax)
fn.variables['z_range'][0]=zmin
fn.variables['z_range'][1]=zmax
print "Writing array"
nsp=Numeric.asarray(z.shape)
fn.variables['dimension'][:]=nsp[::-1]
fn.variables['z'][:]=Numeric.ravel(z[:])
fn.close()
return
def gdal_2_gmt(filename):
"Convert GDAL grid to GMT grid."
z = []
# Open File with GDAL
ds = gdal.Open(filename)
if ds is None:
print 'Unable to open ', filename
sys.exit(1)
bands = ds.RasterCount
print "bands = %d"%(bands)
xsize = ds.RasterXSize
print "xsize = %d"%(xsize)
ysize = ds.RasterYSize
print "ysize = %d"%(ysize)
band_type = ds.GetRasterBand(1).DataType
print "band type ", band_type
# projection = ds.GetProjection()
# print "projection ",projection
geotransform = ds.GetGeoTransform()
print "geotransform ",geotransform
ulx = geotransform[0]
print "ulx %f"%(ulx)
uly = geotransform[3]
print "uly %f"%(uly)
lrx = ulx + geotransform[1] * xsize
print "lrx %f"%(lrx)
lry = uly + geotransform[5] * ysize
print "lry %f"%(lry)
xcellsize = geotransform[1]
print "xcellsize = %f"%(xcellsize)
ycellsize = -geotransform[5]
print "ycellsize = %f"%(ycellsize)
print "Reading Data"
z = ds.ReadAsArray()
# Test the NCAR's 'C' regrid extension :-))
# newxsize = 2049
# newysize = 2049
# print "newxsize = %d"%(newxsize)
# print "newysize = %d"%(newysize)
# r =
adamsregrid.Regrid(xsize,newxsize,'cubic',1,ysize,newysize,'cubic',0)
# z = r.rgrd(z)
# create Numeric array from Python array
# z = Numeric.array(z,Numeric.Float32)
# if z.shape[0] == 1 or z.shape[1] == 1:
# z = Numeric.ravel(z)
# xcellsize = math.fabs(lrx-ulx)/(newxsize-1)
# ycellsize = math.fabs(lry-uly)/(newysize-1)
# print "new xcellsize = %f"%(xcellsize)
# print "new ycellsize = %f"%(ycellsize)
x = [ ulx, lrx, xcellsize ]
y = [ lry, uly, ycellsize ]
# call our GMT grid file writer
basename,ext = os.path.splitext(filename)
filename = "%s.grd"%(basename)
print "Creating %s"%(filename)
wgrd(z,x,y,"%s"%(filename),title="no_title",name=basename,
scale=1.,offset=0,xunit="degrees",yunit="degrees",zunit="meters")
if __name__ == '__main__':
if len(sys.argv) == 2:
gdal_2_gmt(sys.argv[1])
else:
print "%s expecting 1 arg < filename to convert to GMT grid
>"%(sys.argv[0])
