GDALDestroyDriverManager() and static driver pointers
Frank Warmerdam warmerdam at p...
Wed Sep 4 03:04:03 EDT 2002
Folks,
I have implemented GDALDestroyDriverManager() in response to the request
for a way to
cleanup loaded drivers. However, to make it work smoothly, such that
drivers can be reloaded
properly with a GDALAllRegister() call after destroying the driver
manager, it is important that
we no longer maintain static driver pointers within out driver
implementations.
In the past each driver maintained a static pointer to its GDALDriver
instance. The problem
with this is that this doesn't get "NULLed" when the driver is
destroyed. So, to fix do the
following steps to any drivers not in CVS (I have fixed all these):
o Remove the static pointer.
o Remove any initialization of the poDriver pointer in the GDALDataset.
This will be taken
care of by GDALOpen().
o Change your register function to check if the driver is already
loaded by calling
GDALGetDriverByName().
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at p...
and watch the world go round - Rush | Geospatial Programmer for Rent
