[gdal-dev] gdal build instructions
Paul Selormey paul at t...
Wed Sep 4 10:19:12 EDT 2002
Hello Frank,
Thanks for the update. Anywhere to download the test data for the support
data formats?
Also, this is off-topic - the Shapefile library contains world map data.
What is
the projection of this data? (do you have the ESRI's prj file for it?)
Best regards,
Paul.
----- Original Message -----
To: "gdal-dev" <gdal-dev at yahoogroups.com>
Sent: Wednesday, September 04, 2002 11:04 PM
Subject: [gdal-dev] gdal build instructions
> Folks,
> I have updated the GDAL build instructions somewhat, especially for
> windows. Available at:
> http://www.remotesensing.org/gdal/gdal_building.html
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at p...
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
