[Gdal-dev] Cygwin CVS errors
Norman Vine
nhv at cape.com
Tue Apr 1 10:11:03 EST 2003
Frank Warmerdam writes:
> >>Norman Vine wrote:
> >>>Trying to build GDAL CVS today with Cygwin I get the errors below
> >>>On further investigation I find
> >>>from ograssemblepolygon.cpp
> >>>OGRPolygon *OGRBuildPolygonFromEdges( ... )
> >>>and from ogr_api.h:
> >>>OGRGeometryH CPL_DLL OGRBuildPolygonFromEdges( ... )
> >>>Any advice appreciated
> Norman,
> My gdal/ogr/ograssemblepolygon.cpp (CVS Rev 1.5) has
> OGRBuildPolygonFromEdges()
> defined as expected already:
> /* OGRBuildPolygonFromEdges() */
> OGRGeometryH OGRBuildPolygonFromEdges( OGRGeometryH hLines,
> int bBestEffort,
> int bAutoClose,
> double dfTolerance,
> OGRErr * peErr )
> Could you check that you have ograssemblepolygon.cpp 1.5? I
> don't understand
> why you are seeing something so different. This was apparently
> all resolved
> at the beginning of January.
Ahhhh.... It looks as if at somepoint someone might have updated
the CVS from a not up to date source tree
This would explain things
Norman
* $Log: ograssemblepolygon.cpp,v $
* Revision 1.6 2003/03/31 15:55:42 danmo
* Added C API function docs
* Revision 1.4 2002/03/05 15:15:07 warmerda
* fixed zero tolerance problems
* Revision 1.3 2002/03/05 14:25:14 warmerda
* expand tabs
