[Gdal-dev] Image Reprojection
    Matt Lynch
    matt at terraEngine.com
    Thu Apr  3 12:57:00 EST 2003
Hi Frank,
The gdalwarptest sounds interesting.  To get an orientation I have built
GDAL (the cleanest open source build on a windows box in a long time, by
the way!).
When I try to run gdalwarp I just get a usage blurb.
C:\gdal>gdalwarp -t_srs '+proj=latlong +datum=WGS84' jeffpan2000_10m.tif
out.tif
Usage: gdalwarp [--version] [--formats]
    [-s_srs srs_def] [-t_srs srs_def] [-order n] [-et err_threshold]
    [-te xmin ymin xmax ymax] [-tr xres yres] [-ts width height]
    [-of format] [-co "NAME=VALUE"]* srcfile dstfile
jeffpan2000_10m.tif is in the current directory
out.tif does not exist yet.
The details of jeffpan2000_10m.tif are below
C:\gdal>gdalinfo jeffpan2000_10m.tif
Driver: GTiff/GeoTIFF
Size is 2000, 2000
Coordinate System is `'
Origin = (644995.948217,5518006.066294)
Pixel Size = (10.000000,-10.000000)
Metadata:
  TIFFTAG_DOCUMENTNAME=jeffpan2000_10m.tif
  TIFFTAG_SOFTWARE=ImageMagick 5.5.2 12/01/02 Q8
http://www.imagemagick.org
Corner Coordinates:
Upper Left  (  644995.948, 5518006.066)
Lower Left  (  644995.948, 5498006.066)
Upper Right (  664995.948, 5518006.066)
Lower Right (  664995.948, 5498006.066)
Center      (  654995.948, 5508006.066)
Band 1 Block=2000x4 Type=Byte, ColorInterp=Gray
Have I got the syntax wrong?  Or is it because the image is in 10TM
which is not recognized?
Thanks,
Matt
-----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org] On Behalf Of Frank Warmerdam
Sent: Thursday, April 03, 2003 7:56 AM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] Image Reprojection
Matt Lynch wrote:
> Hi,
> I am interested in writing or using a windows command line utility
> which will reproject GeoTiffs for me.  It seems that the gdalwarp
> utility is what I want.
> So I have a couple of questions ...
> 1.  Am I correct that gdalwarp will reproject GeoTiffs for me?  (e.g.
> UTM to Decimal Degrees) 2.  Are there some usage examples that I can
> refer to?
Matt,
I trust you have read the modest docs at:
   http://www.remotesensing.org/gdal/gdal_utilities.html#gdalwarp
Yes, it can reproject GeoTIFF files from UTM to decimal degrees.   The
only
example is the one in the documentation.  To do what you want you might
use:
  gdalwarp -t_srs '+proj=latlong +datum=WGS84' in.tif out.tif
Note, there is also a "gdalwarptest" in the CVS version of GDAL with
similar commandline options as gdalwarp, but using a much more
sophisticated approach internally.  In particular, it:
  o Supports a all pixel types, not just 8bit like gdalwarp.
  o Will work on images that cannot be held completely in memory.
  o Supports a variety of resamplig kernels.
  o Has "NODATA" support.
Gdalwarptest is the "test harnass" for this next generation warper.
Depending on your needs I would appreciate help in testing this new
implementation.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.467 / Virus Database: 266 - Release Date: 4/1/2003
Outgoing mail is certified Virus Free.
