[Gdal-dev] Image Reprojection
Matt Lynch matt at terraEngine.com
Thu Apr 3 13:24:20 EST 2003
Hi Frank,
>I believe this is a commandline parsing issue.  The '+proj=latlong
+datum=WGS84' would be parsed as a single argument by a Unix shell, but
the DOS shell doesn't work the same.
That makes sense.  I added a forth option and used double quotes (I can
recall using them in the past within dos to bypass the whitespace).
Now I get
C:\gdal>gdalwarp -t_srs "+proj=latlong +datum=WGS84" jeffpan2000_10m.tif
out.tif
ERROR 1: Failed to import coordinate system `'.
Creating output file is that 2000P x 2000L.
:0...10...20...30...40...50...60...70...80...90...100 - done.
The output file is created, but it doesn't look like the conversion
happens.  The line 'FAILED to import coordinate system' is probably the
source of my trouble now (image is in 10TM).
How can I specify a input coordinate system like 10TM
Thanks,
Matt
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.467 / Virus Database: 266 - Release Date: 4/1/2003
