[Gdal-dev] SQL
Fri Apr 11 09:00:02 EDT 2003
Krzysztof Chodak wrote:
> Would anyone be so kind and tell me what is wrong with such query:
> ogr2ogr Dolnośląskie miasta_granice -where "Wojewodztw like %Dolno%"
> It reports: ERROR 1: Syntax error, 2 extra tokens
> Are "where" clauses supported for ESRI shapefiles?
The string you are comparing to needs to be quoted.  Try using:
   ogr2ogr Dolnośląskie miasta_granice -where 'Wojewodztw like "%Dolno%"'
If you are doing this on windows the escaping rules may vary.
PS. I tried a similar where clause in Oracle and found I needed to quote
the string token used in the LIKE test as well.
Best regards,
