[Gdal-dev] gdal_translate cutting image error?
Frank Warmerdam
warmerdam at pobox.com
Fri Apr 25 15:01:48 EDT 2003
pond bear wrote:
> I use gdal_translate to cut geotiff file. But the output file can't be
> viewed by ERDAS IMAGE 8.5. The ERDAS says "LayerRasterRead failed" and
> "etif_BlockRead failed".
> Does anybody meet the same error?
Jing,
Can you provide a small file that Imagine has trouble reading? I will test it
with 8.6 and if it doesn't work I will either fix GDAL, fix Imagine (I do some
work for them on the geotiff support), or submit a bug report to them.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
