[Gdal-dev] creating shape files
Frank Warmerdam
warmerdam at pobox.com
Sat Aug 2 20:01:49 EDT 2003
Brian Marchand wrote:
> I’m going to answer my own questions starting with the second one. Yes
> it appears that all features in a layer must all be using the same
> feature definition. You can set this in the OGRLayer by, iterating
> through the field definitions of the appropriate feature definition and
> calling the CreateField method of the OGRLayer with each field
> definition. This must be done before calling the CreateFeature method of
> the layer otherwise the fields of the feature will not be added to the
> dbf file. If this is not the preferred way to handle writing out
> features please let me know.
Brian,
Your assumptions are correct. All fields for a layer should be added
using CreateField() before any features are created on the layer. For a
few formats it may be possible to add fields on populated layers, but this
is not generally possible.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
