[Gdal-dev] Simple matrix to geotiff example.
Eric
carr at tiem.utk.edu
Tue Aug 19 18:01:25 EDT 2003
Dear List,
I have been recently looking at GDAL library to output a simple geotiff
from an int array with known spatial location in C++. I assume that I would
need to use the create method verse the createcopy but have been unable to
get a version using the api examples to work. Any body know of some simple
demonstration code along this line.
Thank You
Eric Carr
