[Gdal-dev] Building GDAL by MinGW
Norman Vine
nhv at cape.com
Mon Aug 25 18:02:13 EDT 2003
Frank Warmerdam writes:
> Assuming line 174 reads:
> pSymbol = GetProcAddress( (HINSTANCE) pLibrary, pszSymbolName );
> Try changing it to:
> pSymbol = (void*) GetProcAddress( (HINSTANCE) pLibrary, pszSymbolName );
> If this fixes the issue let me know and I will correct the master. The
> code in this win32 implementation was written for VC++ and this may be the
> first time it has been used with another compiler.
Frank
This works
I had made this change in my MingW32 code but hadn't submitted a change
HTH
Norman
