[Gdal-dev] Re: undefined python objects
Christopher Fonnesbeck
chris at fonnesbeck.org
Mon Dec 1 17:09:48 EST 2003
On Dec 1, 2003, at 4:11 PM, Sean Fulton wrote:
>> I am trying to compile GDAL on OSX with python support, but I get the
>> following errors on building:
>> <SNIP>
>> The only advice I have seen so far is to compile without python
>> support, but thats not really a solution. Python support is the only
>> reason I am looking to use GDAL.
>> Thanks in advance,
> Chris,
> The python that comes with OS X isn't set-up the way it is on other
> OSs. There is no shared library (i.e. libpython.so or
> libpython.dylib), at least on 10.2, to which GDAL can link . I *think*
> 10.3 has python as a framework in which case you may be able to link
> against /Library/Frameworks/Python.framework/Versions/Current/Python
> by passing '-framework Python' to the linker. Or you could try
> creating a soft link from /path/to/lib/libpython2.3.dylib to
> /Library/Frameworks/Python.framework/Versions/Current/Python.
> I think you can build python as a framework by hand if you're not on
> Panther. Searching python.org will probably be more useful than I have
> been. The GDAL developers probably don't have the time or resources to
> hunt down platform inconsistencies like this, so I'm sure they'd
> appreciate any help in resolving it.
> Good luck, and let us know if you get it working!
> Sean
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
I have used "-framework Python" as the python link arguments, and based
on the build output, I think it finds it:
g++ -Wall -O2 -I../port -I../port -I../gcore -I../ogr
-I/System/Library/Frameworks/Python.framework/Versions/2.3/include/
python2.3
python2.3 -c gdalnumeric.cpp -o gdalnumeric.o >/dev/null 2>&1
It still, however, gets the undefined symbols that I cited previously.
If it finds the framework, then the problem lies elsewhere, doesnt it?
Thanks again,
Chris
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
