[Gdal-dev] OGR/Shapefile crash
gdal-dev-admin at remotesensing.org
Mon Dec 8 14:30:53 EST 2003
gdal-dev-admin at remotesensing.org wrote:
> I sent this to Frank directly, then decided to subscribe and post to
> this list instead. Sorry for the duplicate to you Frank. I added a
> bit more info in this one though.
> ---------- Forwarded message ----------
> I remember a while back having segfaults with Shapelib when trying
> to open a dataset that was corrupted. I think that one had too few
> vectors to go with the dbf file. I had no way around the segfaults,
> which would crash Xastir, other than deleting the corrupted files.
> Also got segfaults if I tried to access a field index that was
> higher than available.
> Question #1, Shapelib:
> Is there any way to have the Shapefile library incorporate simple
> checks so that segfaults are avoided and error codes are returned
> instead?
Curt,
Is not my intention that shapelib would crash when in response to
normal sorts of invalid arguments. If you can detail the situation
and submit it via the Shapelib Bugzilla (http://shapelib.maptools.org)
I will look into improving things for the next release.
> Question #2, OGR:
>>As I try to get OGR integrated into Xastir, I'm getting segfaults
>>any time I try to open a Shapefile dataset that includes a .prj
>>file. Is it something I'm doing, or perhaps the PROJ.4 installation
>>on my system?
>>Note: Using Xastir with Shapelib, I can open these files. Using
>>OGR, I can open them. Once I add the .prj file into the mix,
>>Xastir/OGR segfaults, Xastir/Shapelib can read them just fine.
>>Datum translations using libgeotiff are working fine in Xastir.
>>Datum translations using OGR appear to be working for TIGER/Line
>>files. We're just having this segfault problem with Shapefile .prj
>>files (so far). Segfaults are bad for us. Ours is a long-running
>>program, and we'd like a way around segfaults in all cases.
> Never mind on this one! On one system with older? GDAL/OGR, it
> segfaulted. On another system, with CVS GDAL/OGR, it opened it just
> fine with both methods, with a .prj file present. I'll update the
> other system and things will hopefully be fine there.
Ahh, good.
> Question #3, OGR:
> The available docs for datum translation using OGR are mostly in
> C++. The text mentions that the Transform() method returns
> OGRERR_NONE on success. In 'C', I'm getting a '1' returned, but the
> operation appears to succeed otherwise. Your short 'C' example
> seems to show that '1' is the proper return code as well. Thoughts?
> Am I doing that one right?
The OGR Projections tutorial was wrong on this point. The Transform()
method returns TRUE (non-zero) on success or FALSE (zero) on failure.
I will correct the OGR Projection Tutorial.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
