[Gdal-dev] OGR: C API for Polygon/Multipolygon?
Frank Warmerdam
warmerdam at pobox.com
Tue Dec 9 16:58:25 EST 2003
gdal-dev-admin at remotesensing.org wrote:
> On Tue, 9 Dec 2003 gdal-dev-admin at remotesensing.org wrote:
>>For reasons that seemed good at the time, I did not make some of the C
>>geometry functions mirror the C++ that closely. To access the rings of
>>polygons you use OGR_G_GetGeometryRef(). To find out how many rings there
>>are use OGR_G_GetGeometryCount(). This essentially treats polygons as a
>>contain of rings. You then fetch the points from the rings the same way
>>you would with a linestring.
> Thank you! I have polygons getting drawn now. Was pulling my hair
> out trying to decide whether I needed to implement some C wrappers
> for some C++ functions myself.
> Here are the types that I have in my code:
> case 1: // Point
> case 4: // MultiPoint
> case 0x80000001: // Point25D
> case 0x80000004: // MultiPoint25D
> case 2: // LineString (polyline)
> case 5: // MultiLineString
> case 0x80000002: // LineString25D
> case 0x80000005: // MultiLineString25D
> case 3: // Polygon
> case 6: // MultiPolygon
> case 0x80000003: // Polygon25D
> case 0x80000006: // MultiPolygon25D
> case 7: // GeometryCollection
> case 0x80000007: // GeometryCollection25D
> Should I assume that for ALL of the more complicated types I just
> need to check how many Geometries there are via
> OGR_G_GetGeometryCount() and then iterate through each of these
> subgeometries, treating them as the simpler types?
Curt,
Yes. Everything but Point, Point25D, LineString, and LineString25D
are treated as if there were collections from the C API point of
view.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
