[Gdal-dev] problem with gdal
hamdi ines
hamdi_ines2003 at yahoo.fr
Tue Dec 9 08:14:59 EST 2003
Hello,
first I want to subscribe in gdallist by: hamdi_ines2003 at yahoo.fr and second I have a question:
I m download gdal-cvs-031203 to read gml file in
grass57,but when i execute the command make (after
> ./configure) the result is:
> >make[2]: Entre dans le répertoire
`/home/versionfinaledocgrass57/versionsforopenevfw-gdal/gdal-cvs-031203/frmts/png'
> make[2]: Rien à faire pour `install-obj'.
> make[2]: Quitte le répertoire
> make -C grass install-obj
`/home/versionfinaledocgrass57/versionsforopenevfw-gdal/gdal-cvs-031203/frmts/grass'
> /bin/sh ../../libtool --mode=compile g++ -I../../port
> -I../../gcore -I../../ogr -Wall -O2 -c -o
> ../o/grassdataset.o grassdataset.cpp
> g++ -I../../port -I../../gcore -I../../ogr -Wall -O2
> -c grassdataset.cpp -fPIC -DPIC -o
> ../o/.libs/grassdataset.o
> grassdataset.cpp: In static member function `static
> GDALDataset*
> GRASSDataset::Open(GDALOpenInfo*)':
> grassdataset.cpp:513: invalid conversion from `int
> (*)(...)' to `int (*)()'
> make[2]: *** [../o/grassdataset.o] Erreur 1
Please can you help me to resolv this problem.
THANK YOU
HAMDI Inés
Do You Yahoo!? -- Avec Yahoo! soyez au coeur de la récolte de dons pour le Téléthon.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20031209/5ae4d0b3/attachment.html
