[Gdal-dev] USGS vs. ESRI vs. OGR
Grabowski, Hank
hgrabows at stk.com
Fri Dec 12 08:44:24 EST 2003
I'm pulling the value for X and Y directly off of the ArcMap measuring
tool. I zoomed into a point on a map that was drawn in the native
coordinate system of the shapefile (so there is no conversion) and then
entered those values into the website tool as you saw them. To find the
WGS84 values I created a layer with the WGS84 coordinate system and then
added the data that had been converted by OGR into WGS84 and allowed
ESRI to auto-convert the data from the native shape file. Again using
the measuring tool I got the exact measurement of the given point. The
difference is quite visible without going into that much detail, but I
wanted to get quantitative differences to help diagnose the problem. I
can try the same computation with the link you gave me in a previous
e-mail and move see what happens. If you guys want I could post the
data, it's very small, on an FTP site for you guys to try and duplicate
the problem I'm seeing.
Hank Grabowski
hgrabowski at stk.com
1-610-578-1000
Experience the analysis and visualization power of STK 5.0 by upgrading
today! Order your free copy at http://www.stk.com to get started!
-----Original Message-----
From: Richard Greenwood [mailto:Rich at greenwoodmap.com]
Sent: Thursday, December 11, 2003 7:11 PM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] USGS vs. ESRI vs. OGR
At 01:38 PM 12/11/2003, you wrote:
>I followed your advise to compare to the USGS tool. The conversion
>results are listed below. As we can see, the ESRI and USGS tools match
>identically (to the precision of ESRI which was lower than the USGS
>solution). There is a convergence parameter from the USGS calculation
>which is significantly larger than the error between OGR and ESRI/USGS.
>Being a novice at this reprojection business, I don't know if that is
>the bounds of the accuracy of the solution. I would tend to believe
>not however, since a 40 minute minimum accuracy would be a
>multi-kilometer error in position. On a hunch I looked at the two
>definitions used for WGS84 by both OGR and ESRI, and their coefficients
>match to reported accuracy. I'll continue investigating this issue if
>no one has any ideas what could be causing it.
>UTM X 597196.62 Meters
>UTM Y 4116325.5 Meters
>Product Lat Lon Convergence
>Scale
> DD MM SS.sssss DDD MM SS.sssss DD MM SS.ss
>Unitless
>USGS 37 11 24.57282 085 54 17.71610 0 39 43.15
>9.99716E-001
>ESRI 37 11 24.57 085 54 17.72
>OGR 37 11 24.76 085 54 17.62
>Hank Grabowski
>1-610-578-1000
The convergence angle is not an indication of error, it is the angular
difference between true (geodetic) north and grid north at a given point
in
a projected coordinate system. Similarly, the scale is the ratio of the
difference between grid and ellipsoidal (sea level) lengths at a give
point
within a projection.
WGS84 and NAD27 are datums, while Albers is a projection. Converting
between projections is rigorous i.e. a single formula can be applied at
any
location in a projection to convert it between projections. Conversions
between datums are approximate. Conversions between datums are usually
done
by interpolation. The datum shift will be different at different places
on
the earth. So it is important that you do not attempt datum conversions
outside of the area of the datum (NAD27 is a localized datum, NAD83 and
WGS84 are not). Are your longitudes above west? And if so, shouldn't
they
be negative?
Corpscon (which is based on Nadcon) is a widely accepted standard for
projection and datum conversion and can be freely downloaded at:
http://crunch.tec.army.mil/software/corpscon/corpscon.html
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich <at> GreenwoodMap <dot> com
(307) 733-0203
http://www.GreenwoodMap.com
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
