[Gdal-dev] Bigger compilation error
Mon Dec 15 09:27:46 EST 2003
Paul Kelly wrote:
> See attached for make output, today's CVS using libtool on IRIX 6.2. It
> stops at seemingly the last stage before creating the shared library. It
> worked fine before (even after libtool introduction), a few months ago. I am
> just sending this to the list as I'm not sure what's wrong.
Paul,
I'm not too sure why things are going wrong.  At the bottom I see:
ld: FATAL 43: cannot mix PIC and non-PIC: .libs/libgdal.la-2.o.
Did you used to get this?  It almost looks as if something is being compiled
without libtool and it's -fPIC flags. I presume a clean build doesn't help?
Best regards,
