[Gdal-dev] convert GTIFF(NED) to BMP
Andrey Kiselev dron at ak4719.spb.edu
Mon Feb 3 13:56:45 EST 2003
On Mon, Feb 03, 2003 at 10:43:43AM -0800, Ayman Kamal wrote:
> I appreciate very much if u can help me in finding
> such tool to help me in opening 32 bit floating point
> GeoTiff NED data
That's easy --- try OpenEV. You are already have it!
By the way, if you will need to convert your dataset in othe formats,
for example, BMP, gdal_translate may be invoked in such way:
gdal_translate -of BMP -ot Byte -scale <infile.tif> <outfile.bmp>
You may convert your data using OpenEV GUI as well.
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
