[Gdal-dev] OpenEV licence
Andrey Kiselev
dron at ak4719.spb.edu
Wed Feb 5 14:08:52 EST 2003
On Wed, Feb 05, 2003 at 05:36:35AM -0800, Ayman Kamal wrote:
> I found at http://remotesensing.org/gdal/faq.html
> that GDAL is free, does the same apply to OpenEV?
GDAL distributed under X/MIT license, OpenEV comes with GPL.
You can do what you want with GDAL except removing copyright messages
from sources, OpenEV usage is more restricted: you can't use sources in
closed non-free projects.
And finally yes, both projects are free (but in different flavors).
Andrey V. Kiselev
Home phone: +7 812 5274898 ICQ# 26871517
