[Gdal-dev] GDAL data model, caching, GDALProjDef
Jim Julian
julian at preferred.com
Mon Feb 17 12:21:58 EST 2003
Hi again Derrick,
Forgot to mention, since GDAL includes some vector related software,
you might use GDAL ( or perhaps OpenEV) to create the template and
perhaps even make the cut. I'm not so well versed in the programs to be
able to make a definite recommendation.
Jim Julian
At 02:08 PM 2/16/03 -0500, you wrote:
>On Thu, 13 Feb 2003, Frank Warmerdam wrote:
>1) Is there a way I'm overlooking to decollar collared maps (in GeoTIFF
>form) or is it expected that an external program would be used for this? I
>understand that the georeferencing is insufficient to know where the image
>corners are, but I have other data which can be used for this.
