[Gdal-dev] Problems with gtiff projections
Frank Warmerdam
warmerdam at pobox.com
Sun Feb 23 00:46:54 EST 2003
Roger James wrote:
> Frank
> I am using a build from CVS from two days ago. I will do some further
> checking. These are the results I have at the moment.
Roger,
As you traced, the problem is the lack of projop_wparm.csv. I hadn't
thought that GDAL would require it because normally when resolving a PCS
code it does so using the pcs.csv table, but libgeotiff - used by GDAL -
also requires the projop_wparm.csv table. I have incorporated it into
gdal/data in CVS. The next nightly snapshot should include it.
Alternatively you can separately install libgeotiff 1.2.0 which installs this
an many other tables in /usr/local/share/epsg_csv. I have this installed
which is why things worked for me.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
