[Gdal-dev] Determining Opened File Format?
Sun Feb 23 04:10:06 EST 2003
Ayman Kamal wrote:
> Your technique didn't work, I tried it with two files
> of type TIF ( not GeoTiff )
> and your code didn't return that the file format isn't
> GeoTiff
> here is the code snap:
>    GDALDriverH hInputDriver;
>    const char *szShortDriverName;
>    hInputDriver = GDALGetDatasetDriver( hDataset );
>    szShortDriverName = GDALGetDriverShortName(
> hInputDriver );
>    if ( 0 != strcmp(szShortDriverName,"GTiff") )
>       printf("\nThis is not a GeoTiff file format\n");
>       return 1;
Ayman,
TIFF and GeoTIFF both go through the GTiff driver.  There is no certain
way of establishing that a TIFF file is not also a GeoTIFF file through
GDAL, but if the driver is "GTiff", and projection string is "" and the
geotransform is [0,1,0,0,0,1] then it is likely not a geotiff file.
Best regards,
