[Gdal-dev] hdf4 metadata
Norman Vine nhv at cape.com
Wed Feb 26 17:38:05 EST 2003
Hi All
I am not sure if the following is a problem with GDAL
or my hdf4 library
With gdalinfo I constantly get
Driver: HDF4/Hierarchical Data Format Release 4
Size is 512, 512
Coordinate System is `'
Metadata:
  GPOLYGONCONTAINER=-103.892405, -81.954139, -86.270138, -107.052668
  GRINGPOINTLATITUDE=20.525827, 17.337449, -0.496254, 2.465055
  GRINGPOINTSEQUENCENO=1, 2, 3, 4
the data for GRPOLYGONCONTAINER is I would expect for
GRINGPOINTLONGITUDE
Is anyone else seeing this ?
This is using Cygwin
Cheers
Norman
