[Gdal-dev] projection coordinates support
April Shimitz
shimitz at usgs.gov
Thu Jan 9 12:19:38 EST 2003
Frank,
We are going to explore the option of using GCP's to define our corner
coordinates. There are still some issues with this, but we can push those
off for now as long as we can get the GCP's working for now.
Thanks!
April Shimitz
USGS/EROS Data Center
SAIC
Programmer Analyst
Land Analysis Systems (LAS)
shimitz at usgs.gov
Frank Warmerdam
<warmerdam at pobox.com> To: gdal-dev at remotesensing.org
Sent by: cc:
gdal-dev-admin at remote Subject: Re: [Gdal-dev] projection coordinates support
sensing.org
01/09/03 08:44 AM
Please respond to
gdal-dev
April Shimitz wrote:
> Frank,
> We've been having some issues with accuracy when using the
> Get/SetGeoTransform methods to pass our corner coordinates through GDAL.
> The transformation coefficients retrieved with GetGeoTransform are not as
> precise as the values given to SetGeoTransform. I noticed your note on
the
> GDAL doc. that you are not completely happy with this mechanism either.
April,
Could you point me to this comment in the docs? It doesn't ring a bell.
I am not sure why there would be a problem with the accuracy (precision?)
of Get/SetGeoTransform() assuming the image is actually sampled on an
exact grid in the image projection.
> Do you have any plans for improvement of this in the near future? Since
LAS
> only needs the functionality to store the coordinates at the extents of
the
> image, we'd like to have the ability to do that more directly. We have
been
> considering developing a new class to store/retrieve the corner
coordinates
> and would like to move on that now. Our plan for the class is a simple
> object to contain the exact projection corner coordinates, removing the
> usage of an intermediate transformation equation, thereby returning to
the
> caller the exact values that were set in the object. This class would be
> useful to a number of other format drivers as well I am sure (including
> ones we plan to develop in the future), so I'd like to implement it as
part
> of the GDAL core. Let me know if we should move forward with this plan or
> if you have any ideas/input.
I think that if the GeoTransform isn't an exact way of describing the image
georeferencing you should be using the GCP API. This allows you to
associate
an arbitrary number of control points with the image. Each control point
associates a georeferenced position with a given pixel/line location. In
your case these might be corner locations. For other images GCP coverages
are
used to approximate more complex underlying georeferencing models.
Let me know if you need pointers on the GCP API of if you know of a reason
why it isn't adequate to represent the corner coordinates you want to
offer.
I am hesitent to introduce any additional georeferencing mechanisms if the
existing ones can be used. It is already hard to write a GDAL application
that understands the two existing georeferencing mechanisms (geotransform
and gcps).
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Programmer for Rent
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
